Getting added to UKLPG/Drive LPG register
carguy143
#1 Post by carguy143 »
Hi all.
My new insurance company has asked for a UKLPG approval certificate for a conversion i had done in March 2013. The problem is I don't have one as the conversion centre I used isn't part of the UKLPG scheme. I now have 14 days to get it added. Is it just a case of me contacting my local UKLPG centre and asking them to check it over? Also, will they check over systems they don't actually install? My car has a Stag kit and the local place to me, according to the drive lpg website, only appears to install BRC and only services BRC and Pharos.
I'm in Preston, Lancashire if anyone can advise me further on this.
Thanks.
Rik.
Re: Getting added to UKLPG/Drive LPG register
#2 Post by rossko »
Ask 'em. They can choose to inspect any brand; equally, they're not obliged to inspect outsiders at all. Usual charge is in th £80 -£100 league.
carguy143
#3 Post by carguy143 »
Thanks. Do you have any idea how long the inspection usually takes?
#4 Post by Gilbertd »
If it's done properly, a couple of hours. That's what you're paying for, a couple of hours labour for a skilled and qualified worker. If they find anything that doesn't comply, they will obviously charge you extra to put it right.
carguy143
#5 Post by carguy143 »
Gilbertd wrote:If it's done properly, a couple of hours. That's what you're paying for, a couple of hours labour for a skilled and qualified worker. If they find anything that doesn't comply, they will obviously charge you extra to put it right.
Well yes, I would obviously like it done properly. I'll give the local place a call tomorrow and see if they can fit me in soon. I hope they can as the new insurance company are the ones asking. Admiral didn't care about UKLPG as long as I could provide an invoice for the garage that did the work (profess).
Thanks for all your help everyone.
57jam89
#6 Post by 57jam89 »
Hi carguy143,
What car do you have? Is it a MG ZT 190+ in Nocture blue?
sijones
#7 Post by sijones »
You'll have to update us on if it passes or if it fails what it fails on, i've heard profess have been refused approval for uklpg because there work isn't up to scratch so would be good to hear back.
carguy143
#8 Post by carguy143 »
57jam89 wrote:Hi carguy143,
It sure is. :)
carguy143
#9 Post by carguy143 »
I certainly will. It seems like a lot of LPG fitters have a thing against profess. I spoke to one about getting it certified. He agreed to look at it but only after asking a load of questions about who fitted it, why it wasn't registered and basically telling me it may fail on pretty much everything and could cost more to bring it up to standard than it would have done to get a conversion off them in the first place. I know they're a business and want to make sure they're putting their name against something sound but this guy sounded a little OTT.
#10 Post by classicswede »
The issue is that the car can be inspected by UKLPG and the inspector you use will want to make sure that it will pass should that happen as it would be a strike against them. The inspection does need to be quite in depth to make sure all the parts are of the correct spec and type etc.
I think the point they were making is that by the time you add in the cost of inspection the savings by going to somewhere like Profess can be lost and even cost more when remedial work has to be done
#11 Post by Gilbertd »
The sort of thing that a done-in-a-day conversion will fail on is things like the filler installation. The Code of Practice against which the car is inspected says that the filler must be mounted in such a way that the filler remains attached to the car and the break off on the hose breaks if you were to drive off with a filler still attached. A lot of installers will put the filler in a plastic bumper which is fine but only as long as there is a steel bracket behind it attaching it to the structure of the car and not just relying on the filler being attached to the plastic. If you've got a steel bracket behind the bumper then that's one thing you won't fail on but I would suspect you haven't as it's something that would take time to fabricate as no two cars are going to be alike.
carguy143
#12 Post by carguy143 »
classicswede wrote:The issue is that the car can be inspected by UKLPG and the inspector you use will want to make sure that it will pass should that happen as it would be a strike against them. The inspection does need to be quite in depth to make sure all the parts are of the correct spec and type etc.
Yeah i can understand that. I just don't want to be taken for a ride, if you know what i mean. If something genuinely needs fixing then fair enough.
Thanks for all the help and advice on this one. This is ongoing and I will update accordingly once the issue is resolved.
Rik.
carguy143
#13 Post by carguy143 »
UPDATE: I've just spoken to Profess who are going to take the car to be inspected and added to the UKLPG register.
carguy143
#14 Post by carguy143 »
Well that was easy. I took the car back to Profess for a quick checkup, and then I took the car on to a local (to them) garage. It's now on the UK LPG register and didn't need any alterations in order to do so either. I guess this means that Profess' work is up to standard after all.
SimonHobson
#15 Post by SimonHobson »
It may mean it's up to spec, or it may mean they have a "cosy relationship" with the other outfit. Either way, you've got the "bit of paper"* you need to keep some box ticker happy.
* Metaphorically speaking.
Land Rover 110 V8 LPG
http://www.diy-lpg.co.uk
#16 Post by rossko »
carguy143 wrote:Well that was easy. I took the car back to Profess for a quick checkup, and then I took the car on to a local (to them) garage. It's now on the UK LPG register and didn't need any alterations in order to do so either. I guess this means that Profess' work is up to standard after all.
Having read the brief news item referenced by this thread
http://www.lpgforum.co.uk/viewtopic.php?f=33&t=12499
Confident it is really on the UKLPG register? Its easy to check, visit
http://www.drivelpg.co.uk/
and enter your reg number
carguy143
#17 Post by carguy143 »
Yes I am as I drove the car to the other garage myself after Profess checked it over. I've had no issues with Profess whatsoever. I'm following the other thread very closely though. I also took the liberty of checking the drive LPG register for myself, too.
Rik.
patnut
#18 Post by patnut »
Hi Rik, I may have the same problem too when I change insurance company. How much did the other garage charge you to do the check.
Thanks Pat
carguy143
Re: Re: Getting added to UKLPG/Drive LPG register
#19 Post by carguy143 »
patnut wrote:Hi Rik, I may have the same problem too when I change insurance company. How much did the other garage charge you to do the check.
Thanks Pat
From memory, about £80. Speak to profess if you're worried about it. I seem to remember them doing your 75 if I'm not mistaken.
Rik.
Sent from my Nexus 4 using Tapatalk 4
tom-madbiker
#20 Post by tom-madbiker »
just had mine done at greenflow systems in dagnall dunno what i was worrying about the car sailed through it just an advisory on the filler (which i knew i would get) so thats ok
