smell of gas?
ade-5
smell of gas?
#1 Post by ade-5 »
hi again folks. just a quick one, is it normal to smell gas after running? say I just pulled up for 15 mins gone back out to th car and smelt gas? normal or not? cheers
Re: smell of gas?
#2 Post by Tubbs »
Not normal, and requires further investigation....
ade-5
Re: smell of gas?
#3 Post by ade-5 »
ok. anything I can look for or any reasons ect
cheers
Re: smell of gas?
#4 Post by rossko »
You could try to see which end of the car it comes from to start with; could be the tank at back (will come out underneath somewhere) or under the bonnet.
ade-5
Re: smell of gas?
#5 Post by ade-5 »
well investigation time lol smells like under the bonnet. but spayed some water over th pipes to see if theres any leaks with no joy :-( pain in the ass lol
Re: smell of gas?
#6 Post by Gilbertd »
Use a water and fairy liquid mix (other brands of washing up liquid are available) and spray it onto every joint. You'll easily see bubbles if there are any leaks.
Re: smell of gas?
#7 Post by rossko »
There can be internal leaks that spill gas into the manifold, the smell then wafts out the air intake. Difficult to re-start after a few minutes off?
