Looking to convert my Cayenne in South Wales
gerlewis
#1 Post by gerlewis »
Hi all,
Im trying to read up on LPG, and am conisdering Profess Autogas in South Wales.
They are offering the Stag 300 Premium Kit,
I have a Porsche Cayenne 4.5v8
Does anyone have any words of wisdom, or experience of this engine? I dont know if it requires flash lube, or anything else I might have missed.
Thanks!
Ger
sijones
Re: Looking to convert my Cayenne in South Wales
#2 Post by sijones »
If you want a good install that is cared for and neatly done, don't use someone who will do it in a day. A good conversion will take at least 3 days, and don't be worried if they want it a bit longer.
Getting it installed and setup in a day is just asking for trouble...
Now do profess say they'll do it in a day?.... ;)
#3 Post by Tubbs »
Tommo2009 is an installer on here based in Monmouth. And he has done a few. He gave me a couple of pointers on the one i converted a while back.
gerlewis
#4 Post by gerlewis »
Thanks, Ive contacted him, and am trying to learn a bit more before biting the bullet!
Ger
gerlewis
#5 Post by gerlewis »
A quick question on my quest for more knowledge:
is there any real benefit to an electronic Valve Saver Kit over a vacuum kit on an N/Aspirated engine?
Or should I save £100 and get a vacuum kit?
Cheers!
Ger
sijones
#6 Post by sijones »
vacuum kit's can often stop without you knowing, they also need what feels like constant adjusting as the weather changes.
For the sake of £100 i'd put an electronic one on for peace of mind and knowing the right dose is being done, i really don't think you want to be paying for a rebuild of upper engine (expensive) which is what your going to need if it goes wrong.
gerlewis
#7 Post by gerlewis »
sijones wrote:vacuum kit's can often stop without you knowing, they also need what feels like constant adjusting as the weather changes.
Thanks Si , electronic it its then!
Dai Fish
#8 Post by Dai Fish »
As a previous customer of Profess I personally would not use them again.
gerlewis
#9 Post by gerlewis »
Thanks Dai,
Anyone in South Wales come recommended, or wish to offer their services?
#10 Post by Gilbertd »
See the third post. Tommo2009 on here comes highly recommended.
