I'm wondering wheter I should convert my Avensis?
I've got no clue whatsoever about lpg, can anyone help me please?
Any advice would be appreciated
is this a fact? Because I've heard in the past that some TOYOTA engines (running on LPG) had problems with their valves and valve seats but I think this is a common problem in most engines running on LPG (after thousands of kilometers)stevet284 wrote:I believe the vvti engine has soft valve seats so you will also need a flash lube system installing.
Steve
It's a problem in most Japanese engines but others are not affected at all. Land Rover V8s, BMW, Saab, Volvo, Mercedes and quite a few more do not suffer any problems. Others, such as Honda, are shot in less than 10,000 miles. It depends on the grade of steel used for the valve seats.Tsipouro wrote:is this a fact? Because I've heard in the past that some TOYOTA engines (running on LPG) had problems with their valves and valve seats but I think this is a common problem in most engines running on LPG (after thousands of kilometers)
LOL, lets not get myth confused with fact.Gilbertd wrote:Others, such as Honda, are shot in less than 10,000 miles. It depends on the grade of steel used for the valve seats.
and that is the whole point. Without Flashlube you would have suffered problems but with it you don't. Other engines don't suffer even without it. The list shows the ones that will suffer UNLESS Flashlube or similar is fitted.Speedy999 wrote:Both cars had an electronic flashlube system fitted.
Presumably it can get there somehow, just exactly the same as the lead compounds in leaded fuel/air mix got there in the old days. But maybe that was all a marketing con too.Tsipouro wrote:I am not sure that the oil is likely to end up on the valve seats, its in the air/fuel mix and flies past the valve seats at a considerable speed.
Your privilige, of course. No-one is forcing you to use it.Tsipouro wrote:I still believe that flashlube is not a necessity in cars that were designed to run on unleaded fuel.
Of course.Tsipouro wrote:Did ever those flashlube producers even check an engine head or valve/seats after many miles of running on LPG?
Even more convincing to run one engine with some cylinders 'lubed' and some not?Tsipouro wrote:How hard is it to run 2 identical cars, say 50,000kilometers, strip the heads and show how good your product is?
