AFC Magic Vap, Injectors, Romano ECU
s80wkr
#1 Post by s80wkr »
AFC Magic Vaporiser installed for approx 3,000 miles to Romano System
"AFC Magic Jet reducer for use in SGI kits. Input is a 6mm copper or flexi pipe (see in my store) outputs are 12mm. 1=250hp or 2=350hp
Ther reducer is made of high quality light weight materials and is capable of producing steady 250bhp.
Its max safe working pressure is around 2.5bar
It will work with most SGI kits on the market and with 3 inches in diameter it is one of the smallest out there.
THIS REDUCER IS SUPER SMALL, AND IS AT THE CUTTING EDGE OF LPG DEVELOPMENT.
1 MOVING PART.
IT IS CNC'ED.
AS WITH ALL OF OUR ITEM THIS ONE IS NO EXCEPTIONS AND IT IS MADE IN EUROPE!!
EU and UK approved for use with LPG. 67R"
£60 delivered
AFC Magic Injectors with rail £60 delivered
Set of 4 used for 3,000 miles
Romano "N" ECU £125
