which plugs for merc 200 year 2000
indiana
#1 Post by indiana »
Hi,Am running on lpg and decided to change plugs...Has been running a bit poorly on lpg but fine on petrol.So worth a try but which plugs are the best
Jim
junkcatcher
#2 Post by junkcatcher »
Not enough info --- the 7 digit engine type code is needed it will be something like M111.945
I would suggest you just fit the recommended NKG plug for your vehicles exact engine type code but narrow the plug gap to 0.625mm to 0.7mm (0.025" to 0.028")
indiana
Which plugs
#3 Post by indiana »
Eng No 11194522109268
Have looked through handbooks and cannot find the plug part number or make
junkcatcher
#4 Post by junkcatcher »
really not a good idea to post engine or vin numbers on the web
This site should help with iding the standard plug type http://www.benzworld.org/
