LPG poi file required
ubdai
#1 Post by ubdai »
Does anyone on the forum have a poi file for LPG filling stations that can be used with a iGo gps system.
cheers
ubdai
Active_Lad
Moderator
#2 Post by Active_Lad »
Google's a marvellous thing you know.....
Basically, you'll be lucky. But you can convert TomTom POI files to iGo
You must convert TomTom POI (ov2 format) to Kml format (Google Earth) with POI Edit (using batch converter mode) and then use iGo POI convert to put it in your igo.db
Copy the igo.db on your pc and add POI in Kml format using iGo POI convert then copy the igo.db to you pda (make a backup before)
POI edit is here: http://www.poiedit.com/
I-Go POI convert is here: http://leroy.sebastien93.free.fr/I-Go%2 ... onvert.zip
