After replacing multivalve I'm facing some isues with my lpg system.
After replacing the valve I filled gas about 40 littres ( full tank about 90 littres ).
I opened the screw of the valve in the out line.
Now I have 2 problems.
When I press the on off button to switch the car to lpg, the green light appears, and when the car trying switch to lpg, the engine turn off.
The second problem is that the red light stays when I trying to turn on lpg, and after few seconds it's starting beep.
Any ideas ?
Already checked that the selonoid gets 12 volts.
