System Upgrade
Important forum news
Locked
OnTheFenceDev
System Upgrade
#1 Post by OnTheFenceDev »
I will be installing a system update over the weekend - probably Saturday afternoon.
This should take about an hour unless the upgrade gremlins decide to pay me a visit.
During that time the forum will be inaccessible - wish me luck ;-)
There are 10 types of people in the world - those who understand binary and those who don't.
OnTheFenceDev
Re: System Upgrade
#2 Post by OnTheFenceDev »
System Upgrade complete - the gremlins appear to have focused their attention elsewhere :-)
Re: System Upgrade
#3 Post by Brian_H »
As part of this update a couple of the permissions have been changed to allow moderators to post without having to approve their own posts - This appears to have gone successfully, but if there is any odd/unexpected behavior noticed when you try to post or reply please mention it (either a reply or new topic, or a pm describing the issue).
Initial tests appear to suggest all is working as it should do as far as I can tell.
Thanks Dave!
Re: System Upgrade
#4 Post by Gilbertd »
I still have to mark posts as read though even though I've read them.
OnTheFenceDev
Re: System Upgrade
#5 Post by OnTheFenceDev »
Testing timestamp - apparently there is an issue now that we are back in UTC (clocks went back)
Posted at midday 05/11/2019
Re: System Upgrade
#6 Post by LPGC »
OnTheFenceDev wrote: Tue Nov 05, 2019 12:00 pm Testing timestamp - apparently there is an issue now that we are back in UTC (clocks went back)
That could explain the time of posts on this thread https://www.lpgforum.co.uk/viewtopic.php?f=28&t=15278
Re: System Upgrade
#7 Post by Brian_H »
Not sure if it's just me (I'd mentioned problems with time stamps being wrong yesterday to David) but my profile was set to the wrong time zone. Does the time shown at the top of the page show the correct time for you Simon?
Re: System Upgrade
#8 Post by Gilbertd »
Time shown at the top of the page is correct for me.
Re: System Upgrade
#9 Post by LPGC »
I only see the time top of page on 'board index' and it's reading an hour fast.
My post time agrees with board index time, both an hour fast.
Bottom right of this page says all times are UTC+1
OnTheFenceDev
Re: System Upgrade
#10 Post by OnTheFenceDev »
Form what I can tell the server is currently running on UTC so that should be fine.
At the bottom right of the page I have a note stating 'All times are UTC' and everything looks fine. Brian mentioned that his profile was set to UTC+1 so maybe you need to check there.
Re: System Upgrade
#11 Post by Brian_H »
Its the setting on this page you want to adjust - Click the bit with your name at the top right to see the menu, select the user control panel option, then select board preferences tab and set the timezone dropdowns to the correct options. Not sure why mine was set wrong, but if yours is as well its probably something that was done automatically.
forum setting.png (113.99 KiB) Viewed 19524 times
Re: System Upgrade
#12 Post by LPGC »
Thanks Dave and Bri, done.
Locked
