hi chats my range rover p38 v8 running on a romano system, what it is is when it switches over to gas when first stared in morning I have noted that it feels sluggish till its fully warm!
is this normal??
regards matt
range rover p38 4.6 v8 cold running
- Installer
Re: range rover p38 4.6 v8 cold running
It could be gummy injectors that need a clean out. The cold weather does normally highlight this problem more so
hi thanks for the reply.
how do I clean them out?
iv seem some cleaner on ebay but unsure where I put it.
regards matt
regards matt
- Installer
This is what I now use and it does work well
http://www.classicswede.co.uk/IC_12_Inj ... 79094.aspx
To use take off the rubber hose from the vapour filter and pour some down the pipe and then refit. Run the engine and let the mixture run through. I usually give it 2 or 3 goes.
If it switches over as soon as it is started then it isn't an injection system but a single point. Might be an idea to know exactly what Romano system you have before going any further.matcossy wrote:what it is is when it switches over to gas when first stared in morning
- Installer
Going off previous posts it is multipoint
injector cleaner solved it thanks chaps
