Works fine with my LpgTech and any other LPG make.
Total cost less than 10 quid... All you need is voltage regulator (LM7805), bluetooth module (Arduino HC-06, HC-07) and couple of plugs for whatever ecu you've got.
You can reasign the COM port numbers on the PC.Gilbertd wrote:I considered using one of those Bluetooth modules so I didn't need to get the cable out every time I wanted to check things. The downside I found was that the Bluetooth adapter in my laptop only wants to be COM 6 or 11 and a lot of LPG software will only work if connected on COM 1.
You have to be careful, it's very easy to blow that board , remember about polarity!!!I'll report back in a few days time with what I've blown up .. err I mean how well it went
