I have recently acquired a Land Rover 110 V8 with a Sprint Gas LPG mixer on an Edelbrock 4 barrel carb. It all works fine on LPG, but the vacuum lifter device to allow it to run on petrol is missing. Does anyone know where I can source a replacement?
I have tried several LPG companies in the UK and they all say they no longer deal with Sprint Gas. I have tried contacting Sprint Gas direct in Australia, but no response.
I struggle with the range of the existing LPG tanks so would like the peace of mind that the extra petrol would give me.
Sprint Gas New Generation Active Switch Parts Availability
Re: Sprint Gas New Generation Active Switch Parts Availabili
Device? Do you mean the bladder/actuator, or the vacuum-switching solenoid? There's little value in the mixer parts, not sure anyone in the UK ever stocked spares for it. "Whole unit replacement"?
Well, both parts I think. It looks as though it had been fitted in the past and then removed on failure.
I couldn't even find a stockist of the "whole unit replacement". If you know of a source, I would be interested.
- Installer
I think I can still get the sprintgas mixers but I have found a better alternative that will not fail.
Hello classicswede
Can you let me have details of Sprint Gas parts you can get now. I would also be interested in a longer term solution.
thanks
thanks
