hesitant on acceleration
john_d
Site Admin
Re: hesitant on acceleration
#21 Post by john_d »
i'll swap the MAF's and see what happens.
cheers Tubbsy
Ford Tourneo
Nissan Primastar
#22 Post by Tubbs »
No bother. Do a latch reset though, disconnect the battery, touch the two terminals together, re connect the battery and then hold the revs up (2k) for at least 30 seconds. Let it tick over for a minaute and see what the computer says then.
Just give the engine a bit of time to learn, or re learn its new bit !
tommo2009
#23 Post by tommo2009 »
is this on both petrol and LPG, if it is then it could well be a blocked cat
john_d
Site Admin
#24 Post by john_d »
only gets tested on petrol.
changed the maf and got a reading of 4.6
went in for an mot yesterday and failed for excessive blue smoke, they couldn't complete the emissions test because of the smoke filled garage
I would have thought a blocked would affect performance? she still pulls like a train.
Ford Tourneo
Nissan Primastar
tommo2009
#25 Post by tommo2009 »
I am a little confused now, you say it bogs down under acceleration but still pulls like a train!!!
If the MAf was goosed it would not pull like a train, also if the cat was blocked it would not pull.
This is all irrelevant now anyway as if it really has that much blue smoke coming out then i would say you have more pressing issues.
john_d
Site Admin
#26 Post by john_d »
it was bogging down, I changed the maf and reset the ecu, 1 or both removed the hesitation, I can't see any smoke but 2 garages have said it smokes badly under acceleration, both garage got filled with smoke and the test had to be aborted both times.
Ford Tourneo
Nissan Primastar
sijones
#27 Post by sijones »
change the oil for a thicker one, also put some oil additive in to help keep it thick, might get you through the MOT...
