Starting issues
buddster33
Starting issues
#1 Post by buddster33 »
Hi there, had my car converted to lpg recently and everyting is fine apart from when starting the engine. I have made the following observations:
-If engine is run only on petrol engine will start fine.
-If engine is run on lpg then switched back to petrol for 1 second before switching off engine will start fine.
-If engine is run on lpg and the throttle is blipped (1500rpm) just before switching off engine will start fine.
-If engine is run on lpg and left idling on lpg when switched off it will take several cranks to start if left for between a couple of minutes or overnight.
I have took back to the installer a couple of times who plugged in a laptop but no difference.
System is a sequential AFC G3 with KME reducer and magic injectors.
A search of the forum suggests maybe a leaking injector flooding the intake manifold when switched off?
Any other theories welcomed!
Re: Starting issues
#2 Post by rossko »
buddster33 wrote:A search of the forum suggests maybe a leaking injector flooding the intake manifold when switched off?
Unlikely with new equipment, but not impossible.
Other candidate is poor LPG setting up, leaving fuel trims a way out.
Least likely is poor injection point positioning, leaving a dollop of gas/air mix in the manifold.
andy evans autogas
Re: Starting issues
#3 Post by andy evans autogas »
who fitted the system and when ?. I fit the same system on a daily basis and have never had such problems with them ,the symptoms you are describe are similar to a regulator problem ie leaking gas through the vacuum when the engine is switched off , the only other thing it could be is it's the tuning is so far out and confusing the petrol trims. what car is it fitted to ?..............
Facebook Andy Evans Autogas
buddster33
Re: Starting issues
#4 Post by buddster33 »
Car is a '04 Toyota Aristo (Lexus GS with Supra 3.0 vvti twin turbo engine). I understand what you mean about the fuel trims being out but how would blipping the throttle on gas before switching off prevent the issue?
Re: Starting issues
#5 Post by rossko »
A throttle blip generally resets short-term trims. Whether those would otherwise be "remembered" by the petrol ECU through a stop/start cycle I couldn't say, usually not -but all petrol ECUs behave differently.
Other possibilities were offered. Are you not taking it back to the installer?
