Sorry if I said it incorrectly, that's what I meant about fuel gauge emulator: "AEB392 Emulator for Petrol Gauge Emulation : Emulator used on Renault, Citroën, Peugeot, Lexus and Mercedes ML vehicles to reset the fuel gauge, which indicates a dropping petrol level while the vehicle is running on gas." http://www.gasit.co.uk/index.php?act=vi ... ductId=247
I meant DPI = PDI= GDI =DIG = FSI, From wikipedia: "The gasoline is highly pressurized, and injected via a common rail fuel line directly into the combustion chamber of each cylinder, as opposed to conventional multi-point fuel injection that happens in the intake tract, or cylinder port."
Recommendations for Merc ML500 (2003 v8). S/wales / London
zafira4ever
- New member
tommo2009
- Intermediate Member
Re: Recommendations for Merc ML500 (2003 v8). S/wales / Lond
there are systems on the market that will run with direct injection engines, it still runs a small amount of petrol through to keep the injectors cool.
None of this matters though as the Merc engine is a conventional injection system
