Cat
Nytram
Cat
#1 Post by Nytram »
So now I have LPG do I need the cat?
Martyn
tommo2009
Re: Cat
#2 Post by tommo2009 »
you don't necessarily need the cat. As LPG is tested to a different set of values for emissions, it should pass without the CAT.
However if when you present the vehicle for MOT you fail to tell them it is on LPG there is a fair chance it will fail on emissions.
Can't see why you would want to remove the CAT anyway, you won't notice any difference in performance as the cats these days have a good flow efficiency, unlike earlier cats.
Re: Cat
#3 Post by rossko »
MoT rules are changing in Jan 2012. One of the draft amendments is about failing cars if a cat is absent, when one was originally fitted.
http://www.dft.gov.uk/vosa/publications ... papers.htm
Ricey155
Re: Cat
#4 Post by Ricey155 »
ive scanned about for none cat fitted !! very grey area and nobody really gives you the answer you want (its ok)
my Civic type r Cat has a massive hole and is due for replacement, i was looking for the answer also its flies past the emmisions last MOT, new cat cost (no idea as yet) decat pipe is £120 in stainless
unsure what to do car runs on LPG all the time
Re: Cat
#5 Post by Gilbertd »
Ricey155 wrote:ive scanned about for none cat fitted !! very grey area and nobody really gives you the answer you want (its ok)
Doesn't seem very grey to me.
Section 7.1, new Reason for Rejection 1c: c. a catalytic converter missing where one was fitted as standard.
This was taken from the proposed changes that were on the link that Ross posted above which have now been agreed as nobody objected. The only thing I can't find is when it comes into force (if it hasn't already).
mat_fenwick
Re: Cat
#6 Post by mat_fenwick »
I believe they are due to come into force in January 2012, but haven't seen that from a definitive source.
Ricey155
Re: Cat
#7 Post by Ricey155 »
ive been in the same boat and visited my local MOT guy to ask him, his words and probably not up to scratch
if it passes the emmisions then it passes car or not cat, if it doesn't new cat required or retune if running badly
i was going decat but having tested my CAT its fine so stick with it
Clifford Pope
Re: Cat
#8 Post by Clifford Pope »
A pre July 1992 car is tested on the old carburettor emissions limits, even if it happens to have a cat fitted, as some were. Does this new rule mean that a cat would have to be present, even though it would not need to be working for the car to pass the relevant emissions standard?
mat_fenwick
Re: Cat
#9 Post by mat_fenwick »
Precisely.
lazydocker
Re: Cat
#10 Post by lazydocker »
tommo2009 wrote:However if when you present the vehicle for MOT you fail to tell them it is on LPG there is a fair chance it will fail on emissions.
How so? All my LPG cars have run cleaner on LPG than they do on petrol, even my Range Rover on a single point system :wink:
If it is correctly set up it will pass, especially with the correct test (Basic Emissions Test)
