Hello guys
I contacted an LPG installer to ask him for an instlation for LPG for my GS430 and hes replied with the following
Does he sound right ?
I recommend one of our own 'kits'.
Most people view LPG 'kits' as a list of components made by a single manufacturer. In fact, in an LPG 'kit' each component is made by a different manufacturer. The name of the 'kit' points to only one component in the list of parts. For exactly the same part you can pay twice as much money just because that part has a certain brand-name sticker on it.
We prefer a different approach! We choose the best components - ECUs, injectors, pressure reducers, etc, which are equal to or better than the components that would come with a kit that was branded with a certain name. This ensures we supply and fit systems that are better than any system you could buy with a certain brand name 'off the shelf' and we could do it more cheaply.
For your Lexus I would advise a kit with an AEB based ECU, such as OMVL, Bigas, Tartarini, Zavolli, King. These ECUs are all exactly the same. King is a cheaper, so as they are all exactly the same we'd advise King. Injectors - Would advise MagicJet, Reg, OMVL. OMVL are just as good as the others listed, well proven, good performers and totally reliable so we'd fit OMVL injectors. Pressure reducers - A fairly powerful V8 like in your car needs a high power reducer. This limits you to reducers by Bigas, OMVL, MajicJet, KME gold. As you engine bay space is tight we'd advise MagicJet.
Does this sound right?
Re: Does this sound right?
Oddly enough, yes. As he has said, most control ECUs are manufactured by AEB Electronics with slightly differing firmware to suit different customes requirements. Injectors range from cheap and nasty that wear out fairly quickly and cannot be reconditioned to very good quality that will outlast most cars but can still be dismantled and overhauled should it prove necessary. A Regulator must be capable of supplying sufficient gas for your engines requirements, even at wide open throttle. Again, the differences are quality of manufacture and physical size. I don't have sufficient knowledge of systems to comment on the recommendations but what he is saying is right.
It isn't always the components used, but the quality of the installation and setting up that can make all the difference.
richard_ha
Bare in mind that if you go for a "unique" kit, it may lead to support being harder from other garages.
junkcatcher
With a Lexus you are also going to need a Flaslube kit installed as the material used in the valves are of alower spec than that used european cars, surprising but true.
