Your father was in all probability correct. The porting (exhaust porting) has a further complication in that sometimes (when cylinders are in groups of three) it is more than needed for breathing but has to be open longer to get the benefit of exhaust tuning. Groups of four cylinders can run shorter timing and longer branch lengths but the trade-off is a narrower rpm range of effective pulse tuning.LPGC wrote: Wed Nov 13, 2024 11:23 am I know the basics of how 2 strokes work lol, like you say though the process is more difficult to grasp or explain than 4T, the exhaust and intake kind of happen simultaneously. Could have 2 x 2T engines, both the same size / bore / stroke, both from the same manufacturer, but the porting can make a massive difference to all of torque, bhp and fuel economy (in different measures). Dad used to have a theory about 2T boat outboard engines that an engine with the biggest capacity to bhp ratio (specific power output) would generally be more low rpm torquey and run smoother than one with a higher specific output. At the time you could buy a 70hp or 85hp engine, they'd be the same engine except for a seemingly minor porting difference but the 70 would usually be a 'nicer' engine with a flatter torque curve and use less fuel even at port throttle than the 85.
You are correct on all points. Usually, the exhaust port is open whenever the inlet port is (orifice engine) so no pressure build up in the cylinder is possible so supercharging isn't possible, Porting can be arranged to close the exhaust before inlet closing but this requires asymmetric timing for at least one set of ports. Opposed piston engines with phased crankshafts can achieve it. Rolls-Royce achieved it with the Crecy by employing sleeve valves. In all cases the actual supercharging is slight.LPGC wrote: Wed Nov 13, 2024 11:23 am I don't see much of a distinction between supercharger and blower, unless by blower you mean a setup that gives little boost pressure but delivers the volume of air to the intake port on the 2T? Just something to do away with the need for crank scavenging and maybe reed valves?
Rather than this arrangement being an alternative to crankcase scavenging, it was the original design and crankcase scavenging arrived later.
All true and when direct injection is possible then losing fresh air to the exhaust port can be beneficial to scavenging - but at a cost re the energy to pump the additional air. This has given the 2T a bad rep re 'air work'. The quantities of air a diesel 2T will consume per cycle is around twice that required by SI. That's a halving of air work right there.LPGC wrote: Wed Nov 13, 2024 11:23 amDifferent on the diesel 2T's, in theory a blower/supercharger is more beneficial to a direct injection 2T diesel than to a 2T carb petrol? In fact a direct injection supercharged 2T diesel (like some loco engines) is in many ways easier to understand than a conventional 2T petrol.
If the pressure ratio is low (circa 1.3 ie 5psi above atmospheric) then agreed, the need for an IC is obviated. Blow vs draw through - not so much in it perhaps. Draw and blow through have the same volume of mixture below the blower rotors. The draw through has charge above the rotors but should be shielded by the blowers ie, no flame path.LPGC wrote: Wed Nov 13, 2024 11:23 am If it's not compressing air an intercooler wouldn't be fitted anyway? Still is possible better blow through than draw through to prevent having explosive gas and air mixture inside the blower?
That is difficult to answer as I'm veering away from blower towards a combination of crankcase scavenged with turbocharger.
Everything there is spot on - including recognising the backpressure (can be limited with multi-cylinder design) on port closing.LPGC wrote: Wed Nov 13, 2024 11:23 am I still don't completely follow why you couldn't use a mixer between the blower and the intake port with the reducer referenced to pressure just before the mixer. I could see that working perhaps with a need to lengthen the intake to limit backpressure pulses from the intake port going back/forth through the mixer.
Substitute turbo for blower and crankcase inlet port for direct-into-cylinder port and that's currently what I have in mind. Which is pretty straightforward but for the question of just how much boost pressure the reducer via its reference port can withstand both physically and without losing metering accuracy?
