This is the beastie. It doesn't have a name yet so I need to come up with one for it.
You can see the size it by seeing it next to my spare Range Rover......
The only way that could really happen is if the valve was opening against the prevailing cylinder pressure but an exhaust valve would be opening with a retreating piston lowering cylinder pressure and any water would be forced out of the cylinder during the exhaust stroke so no pressure for the inlet valve to fight. If the head hasn't cracked or distorted, due to the internal pressure then probably OK and in any case, all the valve train components exist independently of the head casting. Head bolts may have stretched though.LPGC wrote: Sun Jun 25, 2023 12:21 pm
I did occur to me that hydrolock could have damaged a rocker / post / pushrod and someone on the boating forum suggested the same. If I find something with the valve train that's wrong and manage to correct it then I'll run another compression test, there is a chance that the head is OK.
The same thoughts had occurred to me... If we think about the 4 strokes and what the valves are doing in all of them there shouldn't be a time when a valve is trying to open against the lock. But I read about other boat engines suffering valve/train damage during hydrolock and I can think of conditions where valves are damaged during closing with a cylinder containing water, still a long shot but one of the reasons boat engines don't normally have a lot of cam duration (i.e. exhaust valve closing after TDC) is to prevent 'reversion' during which if the cylinder hasn't fired a still open exhaust valve could allow water from the exhaust to be sucked into the cylinder. Like you I have my doubts but it seems at least possible.Pinger wrote: Sun Jun 25, 2023 1:20 pm The only way that could really happen is if the valve was opening against the prevailing cylinder pressure but an exhaust valve would be opening with a retreating piston lowering cylinder pressure and any water would be forced out of the cylinder during the exhaust stroke so no pressure for the inlet valve to fight.
Yes they can, the bellows between the transom plate and outdrive didn't survive well either. I found two of the steel plates from the flappers in the bellows, one wedged into the outdrive and one still in the bottom of the exhaust.LPGC wrote: Sun Jun 25, 2023 8:10 pm If your engine has been run without coolant, how are your 'flappers' (rubbers) Gilbert? Apparently they can burn / melt and fall into the exhaust :-( But I've also read they're not completely necessary... I suppose it would depend on how high above the waterline the risers go and how much rocking the boat does with the engine off...
I agree and I suppose an indirect cooling system would probably be a lot better. No different to a car except a water to water heat exchanger instead of a radiator. At least that way the cooling system can be filled with anti-freeze with corrosion inhibitors. That is how it is done on some of the Tournament ski boats that use the all alloy Lexus V8. Mine will be used on the sea but will be trailered there and back. I rescued the cold water header tank from my daughter's house when the boiler was replaced from the old style indirect with header tank and hot water cylinder for a combi boiler. The installer was about to chuck the header tank but it is near perfect size for the outdrive to sit in. That and muffs should keep it well washed out. Mine is fitted with one piece manifolds which don't have the riser bit bolted to the top, just a big curved casting. Apparently, according to the Bayliner forum, they only used them for a couple of years as bad quality internal casting caused a coolant exhaust mix. From the casting marks on mine, they were replaced in 2014 (and I don't think it has had much use since then) so should be good for a while. Replacements are £800 a pair but there's a company that makes a bolt on replacement in stainless steel for, you guessed it, £800 a pair.LPGC wrote: Sun Jun 25, 2023 8:10 pmGot to say though that from an engineering point of view, the car engine'd inboard with outdrives setup do seem to have a lot of shortfalls, especially when moored (instead of trailered) and used on salt water so they don't get rinsed out using muffs like a trailered boat would. Parts like exhaust manifolds and even engines are going to be consumables in that sort of situation. I will be using mine on the sea when it's proven to be reliable (and try not to think too much about the saltwater running through the cast iron block or exhaust manifolds lol) but I'll be rinsing it out with fresh water after every session. On the other hand, I do prefer the inboard/outboard setups compared to outboards.
One company quoted me £150 a day which I thought was pretty good but then they wanted a further £3 per mile to deliver and collect it as it was a self powered job. So if you've got a hire company locally, that still might be an option. I was thinking about making a gantry from scaffolding to attach the chain block to but getting it in exactly the right place for a straight lift was going to be interesting. Then my neighbour (a recently retired Land Rover workshop manager) suggested talking to the local farmer to use his Telehandler before the cherry picker job came up.LPGC wrote: Sun Jun 25, 2023 8:10 pmAhh I thought cherry picker hire would've been around £100 for a day lol. Or buy a couple of 6metre lengths of angle iron and make a frame to mount chain pull lifts to, effectively such angle iron wouldn't cost me anything because I'd eventually use it all to make brackets to attach LPG tanks to RV's.
Good idea. I thought about adding a winch setup to the crane, that way (or your way) the crane arm could remain near horizontal during the entire lift thus keeping it's reach. I have some old 'pull lifts' somewhere, finding them would be another matter! The problem with the winch idea is getting hold of suitable cable rollers and how to attach them to the crane, I've seen a video where someone routed winch cable through the box section of the arm and added small 30mm (but very heavy duty) rollers in the ends of the box section but this crane has adjustable reach (by sliding the narrower box section outer arm inside the wider section inner arm) and the outer section is too narrow for even a 30mm roller to fit inside.Pinger wrote: Fri Jul 07, 2023 9:05 am If the engine hoist is high enough, could a block and tackle be attached to supplement the hydraulic lift travel? The height required though would be significant and raises thoughts of a gantry arrangement as a less topple prone solution.
