WELL , i had a tiny window of opportunity to get the monster onto the dyno last friday .
i have not been able to set the fuelling very well at higher rpm , basically because its so bloody fast at accelerating ...being under a ton and over 350 lbs ft of trq , and big tall wobbly tyres ,means i keep ploughing into corners way too fast ...or going well over my winnebago 7.50x 16 tyres speed limits , i dont mind going over it on the dyno cos i can always run away.
so strapped her down ,and did a few minutes working on the low down tickover and below fueling , so it has a lot more low down trq for trickling in traffic , made a little progress ,still too rich , but its hard to hold steady state over 300 lbs ft at below 1500 rpm ...more work to do on that area it kept falling in a big rich hole at higher throttle opening .
then onto a couple of full throttle runs , with the ecu set on auto tune , so it would set the fuelling for me ,after a fashion .
now judging by these piccys ...
30 mph light throttle..
higher rpm full chat max trq..
i may have just found the trq limit of my rollers with little narrow tyres and no loading !
i am not sure if it shows very well ,but there was a churn load of blue smoke coming off the tyres , also you can see the grated tyre rubber being thrown across the cave as my gritted rollers hone down the treads a touch .
however i did manage to get some readings..
bhp is now up to 354..
that's a graph of my best venturi run with the 2 spinning injection runs , and my theoretical max with grip ...i reckon at around 380 bhp.
then torque at 419 lbs/ft ..
here i reckon on around 435 lbs/ft max theoretical ..however my 419 is still 58 lbs/ft up on the old fueling system...noice
inj run number 2 had more ignition advance , 1 degree more made a fair bit of difference .
now i am aiming for around 13.5:1 air fuel ratio , here you can see the fuelling logs for both runs on both engines ...
engine 1 , the 3.6 litres ..
run 1
run 2
engine 2, the 4.0 litre..
run 1
run 2
you can see how the autotune has modded the fuelling , sometimes over shooting and going too far the other way ,also i am well over 100% duty cycle with these injectors at this 15 psi fuel pressure ,which is a surprise ...and basically means they are wide open non stop ,hence the leanness in the places at the higher rpms .
also these power runs where done on a low load so the tyres had a chance to grip ,so the ecu only had a few seconds to adjust the fuelling before it was run over ...so i am pretty impressed the ecu was able to take a car that wouldn't rev ,to one that would , in just a few pre run rev ups .
also it revved to 6k with little vibration
i think with better fueling and timing i should reach 400 bhp and 500 lbs/ft ....but maybe nor be able to grip it lol. .... for all i know its there already ...it does explain why a blip of throttle in 3rd at 40 lights up the tyres like a volume control.
ok ok ,geekness over
robert.
