lexus hybrid
robbie1944
lexus hybrid
Just wondering I run a Lexus RX300 on lpg and absolutely love the car but it is now getting a bit old so am thinking of buying the Lexus RX450 hybrid but am wondering if it can still be fitted with lpg as a big follower of lpg having used it for many years would not like to go back to petrol
Re: lexus hybrid
The biggest obstacle will be if its direct injection, and reading this https://blog.lexus.co.uk/2gr-fxs-lexus- ... explained/ suggests it is at least partially. This post https://www.lpgforum.co.uk/viewtopic.ph ... ct#p113525 by LPGC explains the situation with DI engines. You'd also want to consider where you might put the tank to avoid losing too much space if you do go down that route (as the hybrids tend not to have the wheel well options as far as I know)
