Brc flashing lights
robbie1944
Brc flashing lights
#1 Post by robbie1944 »
Hi
I am sure this is a common problem but my Lexus RX fitted with a bra kit when the car starts all the lights are on for about 5 minutes then they all start flashing no matter how much is in the tank
Any help would be appreciated
Bob
Re: Brc flashing lights
#2 Post by LPGC »
Usually 1 duff level sender, 2 damaged (chaffed / broken / etc) wiring between ECU and level sender, 3 incorrect wiring to level sender or 4 incorrect gauge calibration in software. If the gauge ever worked properly most likely 1 or 2.
robbie1944
#3 Post by robbie1944 »
It has started working sometimes it just starts to flash after a couple of minutes and it may just work so will leave well alone
Thanks for your reply
#4 Post by LPGC »
No probs
