Red connected to the ignition switched supply (from the feed to the petrol injectors)
Black I assume goes to ground as it disappears into the LPG system loom
Blue is connected to the blue wire on the LPG system so is powered only when running on gas
Yellow and brown wires intercept the ignition retard line between the engine and gearbox ECUs. This uses a 12V PWM signal to retard the ignition timing to reduce torque during gearchanges.
So what the hell is it doing and why? The car drives no differently on petrol or gas and gearchanges are fine on both fuels, no different to my car with a similar LPG system but without this mystery box.
