I got my steel threaded adapter, 5mm hole down the middle compared to the all brass 4mm hole, 25% bigger/more flow there
Since using the new adaptor I rolled up at my local and it wouldnt fill to capacity, slowed to a halt but no clunk from the valve shutting off. Removing the ball valve there and then made no difference either, it took 0.5 litre then halted again. I refitted the valve drove to a different station about 8 miles away and got another 14 litres in easily at a much more regular speed, no slowing/speeding up on the counter.
Today I connected the laptop up randomly to check how the maps were doing just out of interest
Looks like its teaching itself....!
Just been out and done a bit more messing with the mapping, ive raised the pressure to 1.2bar and re-calibrated/deleted the maps to start again.
Used a route of about 10 miles, lots of uphill foot in floor moments and a nice open sweeping national speed limit road on the way back with hardly any traffic to slow things, took three attempts at altering the multiplier to get this result
Im still getting the "injectors fully open" error but the lambdas are now only showing 0 literally at the rev limiter when holding it just under for a few seconds, should be ok as I rarely rev the engine that high at all.
Very different results now though, feels a lot more like its running on petrol, much more power available.
I might see if I can get some time on a rolling road, I take it its the same as far as setting the multiplier?
