Missfire under 2k revs
Posted: Mon May 30, 2011 11:36 am
Hi all,
I'll start by saying i've done a search and i've already changed my spark plugs, coil, HT leads and liquid phase filter.
I have a BRC sequent multi point kit.
The car drives fine on petrol with no misfires.
Under 2000 rpm it misses quite a lot on gas - most prominent at 1750rpm. If full throttle is used under these revs it results in lots of chugging and pops.
I'd say i'd ruled out the ignition system by changing what I have (waste of money!) the only thing i've not changed is the gas phase filter but I doubt it will be that - the liquid phase one was clean.
Which brings me to the question - are my injectors knackered? They've only done 50k and are BRC ones. Can they be rebuilt? (If so by whom?)
Any Ideas?
Edit: Not sure if it's related but when switching the car on it cranks for ages before eventually firing, very embarrassing! If I switch to petrol a minute or so before I turn the car off then it fires quickly like a normal car.
Any Ideas?
