Bigas range rover 4.4 BMW engine
torqueni
#1 Post by torqueni »
I have just fitted a new bias system to my rr had a problem a while back of lumpy on idle got that sorted to much gas pressure so now all was ok for a day or two now the car is cutting out or stalling when the car Is put in park only sometimes has anyone come across this before.
Re: Bigas range rover 4.4 BMW engine
#2 Post by rossko »
It's set up wrong. Re-do your calibration when you tweak the gas pressure. Check the injector type/nozzle size. Did you tweak both halves, assuming you have the siamese unit?
torqueni
#3 Post by torqueni »
rossko wrote:It's set up wrong. Re-do your calibration when you tweak the gas pressure. Check the injector type/nozzle size. Did you tweak both halves, assuming you have the siamese unit?
When i tweak the gas I do a recal every time my injectors are biagiotti fast not sure if that is the right spelling there are black injectors this is what I have picked in the solfware . By tweaking both haves do u mean bank 1 and 2 the kit is a Tinley tec bigas sgis-n
tommo2009
#4 Post by tommo2009 »
do you have the double reducer fitted to the vehicle? If you do, have you tee'd both outputs together.
the gas pressure should be around 1.1/1.2
Done a number of theses engines with the bigas system and never had a problem
