Wanted: Prins VSi Vaporiser / Reducer ~ New or Used
Interiority
#1 Post by Interiority »
Hi There
The reducer / vaporiser on my Prins system started leaking and when removed by the garage to repair, it was so badly corroded together that they can't even open it up to refurbish it, so I need a replacement...either a new one or a second hand one that has been refurbished or at least is know to be working correctly.
The reducer / vaporiser number is: D/42/05/241 and it's for a system fitted around 4 years ago on a V8 4.6 P38 Range Rover
If you have one / know of one it would be great if you could get in touch!
Kindest regards
Jon
projects@interiority.info
07799 338 898
