Page 1 of 2
Fuel guage
Posted: Sat Nov 14, 2009 10:17 pm
by stuart_adair
Hello all,
Just had my Renault Grand Scenic converted to LPG by Professional Autogas of Ystrid Mynych this week. Have to say that the guys there give a superb service.
My question relates to the accuracy of the fuel guage. It has 4 lights when full. As I drove home after the fit...
Went to 3 after 30 miles
Went to 2 after 50 miles
Went to 1 after 80 miles
I filled the tank back up and it took 13 litres so the fuel use was ok.
Tank is 60 litre doughnut tank which is going to give me about 400 miles in all.
I've bought a copy of the configuration software to go with the installation so I can play around with the voltage that each light comes on. Currently set as follows:-
Light 4 > 4 volts
Light 3 >3 volts
Light 2 > 2 volts
Light 1 >1 volt
Any suggestions as to what I should adjust these voltages to ?
Stu :D
Posted: Sun Nov 15, 2009 11:08 am
by junkcatcher
You will not get 400 miles from a 60litre tank closer 300 miles as 60 litre tank needs to have 12 litres of vapour space to prevent over pressurisation in the event of a fire or accident.
Setting the gauge to give accurate results is virtually impossible.
Posted: Mon Nov 16, 2009 9:30 am
by gfrost
Stu,
I had my Megane 225 converted at the same place. I have had a play with the fuel gauge settings but I couldn't get it exactly right. If you have got some petrol in you can just drive it till it runs out of gas, then remember the results.
I have found that I still have over 150 miles left when the red light comes on !
I remember that I changed the "light 1" it was very sensitive and required a bit of trial and error, I seem to remember changing it by a very small amount and the red light went from coming on at >150 miles to go, to never coming on at all
Graham
Posted: Mon Nov 16, 2009 4:45 pm
by stuart_adair
Brilliant - Thanks for the replies. I'll have a play around
Posted: Wed Nov 18, 2009 10:18 pm
by MEP
junkcatcher wrote:You will not get 400 miles from a 60litre tank closer 300 miles as 60 litre tank needs to have 12 litres of vapour space to prevent over pressurisation in the event of a fire or accident.
I was going to say the same. From my Tank with a empty to full capacity of 40L, I will get about 230-260 miles on 40L of gas. And thats in a 1300kg 1.4 Fiat Stilo.
With your car being heavier and bigger engine I'd imagine you'd be getting about the same as me mileage wise TBH.
Jon.
Posted: Thu Nov 19, 2009 8:18 am
by stuart_adair
I'm doing a mileage test at the moment, am up to 210 miles and I'll run it until it runs out of gas.
I'm a bit wary of adjusting the voltage settings on the fuel guage this early in the game as when I click on the fuel guage icon on the management software to adjust the settings a big message comes up telling me it will invalidate the warrenty.
Stu :D
Posted: Thu Nov 19, 2009 10:28 am
by MEP
stuart_adair wrote:I'm doing a mileage test at the moment, am up to 210 miles and I'll run it until it runs out of gas.
Stu :D
How much fuel does it say is left at the mo then?
Posted: Thu Nov 19, 2009 11:00 am
by stuart_adair
There are 4 lights plus the red.
Full = 4 lights
Goes to 3 after 45miles
Goes to 2 after 60 miles
Goes to 1 after 80 miles
Red at 100 miles.
Am doing a mileage test and am up to 270 miles on a full tank so far - The last 170 miles on red.
Stu
Posted: Thu Nov 19, 2009 2:54 pm
by MEP
stuart_adair wrote:There are 4 lights plus the red.
Full = 4 lights
Red at 100 miles.
Stu
so your guage is well out then, lol.
Posted: Thu Nov 19, 2009 5:56 pm
by stuart_adair
You could say that. So far though I've done 300 miles on a 60 ltr tank of gas and I've not run out. Must be running on fumes
Posted: Thu Nov 19, 2009 9:27 pm
by junkcatcher
About 28mpg pretty good
Posted: Fri Nov 20, 2009 2:01 pm
by Nath
My BRC kit normally goes as follows:
0 miles - 4 green
45 miles - 3 green
90 miles - 2 green
135 miles - 1 green
180 miles - 1 flashing green
250 - RED (AKA "empty" :p)
Posted: Fri Nov 20, 2009 3:27 pm
by stuart_adair
To be honest its not the end of the world and I'm just using the mileage to judge the fuel use. Just wondering when I'll run out as I'm up to 320 miles so far.
Stu
Posted: Fri Nov 20, 2009 5:06 pm
by pete_c
i have the 60l donut tank on my astra van 1.6,
i fill up on £28 and it tends to give around 340miles before the red light is flashing like a hookers brothel..i like to empty it completely before i refill and this generally happens on a roundabout and it just stutters and wont pull away!! flick the switch to petrol and off to find a lpg garage.
Posted: Sat Nov 21, 2009 1:39 am
by MEP
stuart_adair wrote:You could say that. So far though I've done 300 miles on a 60 ltr tank of gas and I've not run out. Must be running on fumes
Lol.
Nath wrote:My BRC kit normally goes as follows:
0 miles - 4 green
45 miles - 3 green
90 miles - 2 green
135 miles - 1 green
Almost the same with my BRC kit. What size tank you got and what car / engine size you running it with?
Mine's
0 miles - 4 green
70 miles - 3 green
110 miles - 2 green
145 miles - 1 green
230/260 miles (depending upon driving style) - runs out.
pete_c wrote:i have the 60l donut tank on my astra van 1.6,
An expensive hobby is running out of LPG though. I've only ever done it twice since having LPG fitted in the beginning of Aug. Once thorough mis-judgement of distance to fuelling stations and the other when some silly mare in a KA smashed into the back of my car and I didn't want to re-fuel LPG until the system had been certified safe to continue using.
Posted: Sun Nov 22, 2009 1:12 pm
by stuart_adair
Ok, so finally ran out of gas at 325 miles. It took 56 ltrs to refill and cost me £30.24
56 ltrs = 12.2 gallons / 325 miles = 26.4 mpg
Petrol would be 35 mpg = 9.2 galls = 42.1 ltrs x £1.10 pl = £46.37
Saving over 325 miles is £16.13.
I do 2000 miles a month so monthly saving is £99.19. Payback period is 10 months - Excluding additional payments received for company car use.
I'm a happy man :D
Posted: Tue Nov 24, 2009 1:10 am
by MEP
stuart_adair wrote:Ok, so finally ran out of gas at 325 miles. It took 56 ltrs to refill and cost me £30.24
I'm a happy man :D
Not bad going :)
Posted: Tue Nov 24, 2009 8:20 am
56 litres costing £30.24 means you paid 54p per litre. Have a look around for a different supplier and you could save even more. I'm currently paying 48p per litre from my local Flogas depot so 56 litres from there would be £26.88. Then you'd be saving almost £20 over 325 miles!
Posted: Tue Nov 24, 2009 1:35 pm
by SupraDave
I'm a happy man :D
26mpg from 35 is a fair drop, like 30%.... I wonder what the trims are.
Posted: Tue Nov 24, 2009 7:30 pm
by SAD199
I ran an ordinary scenic 1.6 ltr on a BRC system and never got more than 27 mpg from it. I was disappointed about this because the readout from the comp when running on petrol used to say 35-7 on average. I did a brim test and found that the comp lied, it was nearer 32 mpg. I think they all lie so if you feel up to it try that.
