LPG poi file required
Posted: Thu Sep 17, 2009 10:27 am
by ubdai
Does anyone on the forum have a poi file for LPG filling stations that can be used with a iGo gps system.
cheers
ubdai
Posted: Thu Sep 17, 2009 4:14 pm
by Active_Lad
Google's a marvellous thing you know.....
Basically, you'll be lucky. But you can convert TomTom POI files to iGo
You must convert TomTom POI (ov2 format) to Kml format (Google Earth) with POI Edit (using batch converter mode) and then use iGo POI convert to put it in your igo.db
Copy the igo.db on your pc and add POI in Kml format using iGo POI convert then copy the igo.db to you pda (make a backup before)
POI edit is here: http://www.poiedit.com/
I-Go POI convert is here: http://leroy.sebastien93.free.fr/I-Go%2 ... onvert.zip
