what type of lpg system do i have?
ryncharlton
#1 Post by ryncharlton »
Hi
Just bought a discovery 3.9v8.
how can i tell which lpg system is has fitted? is is sequential or closed loop
Thanks , Ryan
#2 Post by rossko »
It'll tel you on the certificate of safe installation that came with the car .... ah.
Have a look at the dashboard switch for a logo. Have a look under the bonnet, find the gas pipes and hoses, see where they go. If you've a big hose that goes in near the throttle, you've a mixer system. If a bunch of small hoses go in near the petrol injectors, its multipoint.
All disco 3.9 should be fitted with a closed-loop system of either kind.
jayc
#3 Post by jayc »
My 3.9 Disco had an open loop system and ran better, out performed and was better on mpg than a friends with closed loop.
That said i suspect mine was just well set up and his was in desperate need of a tune.
#4 Post by rossko »
jayc wrote:That said i suspect mine was just well set up and his was in desperate need of a tune.
Most likely .. the other possibility is that his had catalysts that still had their innards in place ... ;)
jayc
#5 Post by jayc »
sailed through 3 mots before the chassis rot forced it's disposal so emissions can't of been that bad.
But yes you're right it should really have had some kind of mixture control.
ryncharlton
#6 Post by ryncharlton »
Hi all
yes i do have a mixer system - think its closed loop - has a leonardo control thingy on it.
One problem it does have it cuttng out on gas when hot. it doesent happen all the time but sometimes pulling up to a juntion , dip the clutch and it idles very very slow then dies - restarts and drives fine though? any ideas?
Thanks , Ryan
#7 Post by rossko »
ryncharlton wrote:One problem it does have it cuttng out on gas when hot. it doesent happen all the time but sometimes pulling up to a juntion , dip the clutch and it idles very very slow then dies - restarts and drives fine though?
The most common cause is vaporiser aging, causing it run rich at idle. This can be simply adjusted out ... up to a point, then renewal is recommended.
Leo is a feedback / closed-loop system, yes. Do not leap in and twiddle anything without getting a diagnostic connection to that via laptop - see numerous other threads on this forum.
cheers, Ross K
