Wanted: A "Dodgey" fitter
Posted: Tue Apr 21, 2009 2:08 pm
Hey all
Hoping you guys can shed some light on a confusing subject. Perhaps I should start with my plan:
- 1988 Nissan Skyline (RB30E with minor mods)
- Megasquirt ECU (V3 Board should run LPG injectors directly)
- Some form of LPG injectors (no idea where to source these seperate from a kit)
- Some form of LPG Reducer (also need a supplier for this not in a kit)
- Conformable Tank from Propane Performance Industries (replace existing petrol tank)
So, in the end I'm aiming for a Straight-Gas Vapour Injection system.
I want this to be as DIY as possible.I'm quite confident in my mechanical skills.
Should have minimal problems with:
- Installing the injectors to the manifold
- Installing the tank in place of the petrol one
- Installing the reducer and plumbing to the cooling system
- Wiring up the injectors
- Mapping fuel tables
- Maybe even low pressure hosing between the reducer and the injectors
The MAIN hurdle though is that no gas fitters I've spoken to want to touch the project. It's hard to explain that I really want them just to do the high pressure LPG stuff, check the rest and give me a compliance plate.
I've heard of backyard DIY jobs being taken to fitters here in Aus to be complianced, but can't find anyone who'll do this.
Anybody got some sweet hookups (or advice)?
Thanks in advance
Grant
Thanks in advance
Grant
