LPG Tank
ttalps2000
badger
Filling quantity has absolutely nothing to do with pump pressure. If the pump produces a pressure higher than the internal pressure within the tank, then liquid will flow, it's that simple. Pressure within the tank remains constant due to the incoming liquid trying to increase the tank pressure, causing the vapour in the tank to liquify. The pressure change within the tank whilst filling is in the order of 3 or 4 psi, temperature dependant.
What is more likely happening, is the float arm on the sender unit is incorrectly set. Manufacturers set them up erring on the side of caution, the net result being a tank that shuts off at a lower than expected volume. The shut-off valve is a plunger that is held against gas pressure by the float arm and released, causing the flow to cease, at a set point. I measure all my float heights when assembling them and tend to find that bending the float up by roughly 1" has the tanks shutting off at exactly the right level in most cases.
Different filling quantities at different gas pumps has, in my opinion, been more down to vehicle attitude (sloping one way or another) than anything else. My landrover fill varies by around 4 litres (checked from empty) with a 5 degree slope left or right. Torroidal tanks are the worst in this respect, closely followed by long, small diameter cylinders. I have, however, came across the odd multivalve that will keep flowing at a much-reduced rate off certain pumps.
ynott
Hi Badger
Mine is suffering the same, 105 litre torroidal with max possible of 70 litres when filling parked uphill, 62 litres parked down hill, these figures are from completley empty of at least when the system has switched over to petrol. Is it difficult to remove the float and adjust as you have described?
Thanks in advance and sorry Ynott for hijacking your question..
Kiltyhill
Kiltyhill
badger
You need to vent the system safely to completely empty the tank. I suggest doing it outside on a windy day with ALL doors and windows open!
Once vented, undo pipes and electrical connections, unbolt multivalve from tank, ease out, bend float arm upwards by roughly 1" and reassemble. When filling, put in roughly 3 or 4 litres and run engine on gas and leak check everything disturbed with a soapy water solution. Once happy with leak check, continue filling and see what it takes, including the initial few litres.
SimonHobson
- Intermediate Member
Yes, that really does mean having the tank completely empty and de-pressurised BEFORE undoing the valve.badger wrote:You need to vent the system safely to completely empty the tank.
It's trickier on a toroidal as there is a rubber pipe that is supposed to get vapour from the top of the tank if the relief valve lifts. It tends to slip and can make the float arm stick.Once vented, undo pipes and electrical connections, unbolt multivalve from tank, ease out, bend float arm upwards by roughly 1" and reassemble. When filling, put in roughly 3 or 4 litres and run engine on gas and leak check everything disturbed with a soapy water solution. Once happy with leak check, continue filling and see what it takes, including the initial few litres.
On a 4-hole tank, it's different again - the fill valve needs unscrewing from the tank and you need to be careful that the float arm for that doesn't catch on the dip tube or the float for the contents gauge as you do it.
Land Rover 110 V8 LPG
http://www.diy-lpg.co.uk
Hi Guys
Update on tank fill quantity.
Removed the float and bent as described, now filling 76 litres, definite improvement!!
However! I asked for and was told that I was getting a 105 litre tank but the tank is actuall a 95 litre tank, stamped clearly on the side!!!
I've been conned.
Thanks for your help, mystery solved.
Kiltyhill
I've been conned.
Kiltyhill
whitelion58
- Junior Member
Hello
I have a similar problem with a system I removed from a scapper and fitted to my Rover. It runs great and all is well, but the 90litre cylinder tank never takes more than 40 litres, which really limits the range.
I guess the most likely cause is the float arm being wrong, but any other possible causes? I suppose the angle I mounted the tank at will have an influence, but it looks similar to other installations. How close to "30 degrees" does it need to be?
Suppose I just have to run it dry and pull the float out as already discussed to be sure.
Tim
Tim
whitelion58
- Junior Member
