Help and advice needed
volvo940
#2 Post by volvo940 »
check for valve recession
chobson
#4 Post by chobson »
I have a similar problem with my BMW 523 auto (Prinz conversion)which was converted about 4 weeks ago. It has stalled 8 times in 1000 miles, either when moving off or once when on full lock. I notice that when I engage Drive using LPG, the rev counter drops from about 750 rpm to about 600 rpm at which point also I can feel the engine start to run in a slightly lumpy way. <BR> <BR>It's a critical safety issue if your car stalls when pulling out onto a busy main road. I'll be taking my car back to P&T autos in a few days time for its 1000 mile check up and am hopeful that the problem will be fixed by them / Prinz. <BR> <BR>To get round the problem I ease the revs up slightly with my right foot while keeping my left foot on the brake pedal before moving off. <BR> <BR>I'll let you know what happens after the 1000 mile check up. <BR> <BR>PS I intermittently get an engine management warning light up since the conversion.I guess this means that it's sometimes running either a little rich or a little lean oon LPG.
