These may help
https://1drv.ms/b/s!AigNPuwBlwA-jKRwQbt ... Q?e=dBfSvu
https://1drv.ms/b/s!AigNPuwBlwA-jKRxO61 ... w?e=qgE05I
Actually for OMVL but its the same near enough
Given its going on a P38 it would be a good idea to check out
https://rangerovers.pub/ as well
Be aware that the Thor engine manifold is better done with nozzles into the lower section, this involves making holes in the webbing of the upper manifold. This gets the nozzles closer to the petrol injector location and prevents them being crossed over (once you get the upper manifold off you will better understand why that can be an issue as the pipes up the top feed two cylinders on each bank per side, the middle ones cross over to the other bank)
Not the best photo to show it, but this is the pipework in the Thor 4.0 Disco 2 I've got to show where you ideally want to aim for.
- Manifold.jpg (152.12 KiB) Viewed 2015 times
Also try to make the injector cuts somewhere that they aren't underneath the manifold - its really awkard to get the mainfold back on if you do as I discovered, if you identify the wiring colours used you should be able to break into the loom further up (having just replaced the wiring from this point to the injectors on mine due to poor condition of the cables). I would also advise you to be aware that the middle two connectors on each bank can end up plugged into the wrong injector (they will fit quite easily and not look wrong!) at least I found mine had been swapped over at some point.
