New Burco Urn
Posted: Sat May 21, 2022 6:42 pm
Hi everyone,
I have just purchased a new LPG Burco hot water urn for my food van. The previous 'deluxe' model (which came with the van and is now not fit for purpose) had a fixed connection that fitted straight into the mains pipe in the van via a compression fitting. However, the one I have just bought, which is the standard one, comes with a flexible hose that again needs to be connected to the mains pipe. Now, the issue isn't connecting the hose, I can do that. It's whether I need to use the regulator supplied. The two 19kg bottles that power everything in my van, have hoses that pretty much connect straight to a 37mbar regulator before the gas heads off into the pipes inside the van. With this in mind, can i just connect the new boiler straight to the mains pipe without the additional regulator? (Picture attached). I would happily use it, but I'm not exactly sure how to connect the mail end that would normally screw into the gas bottle, to the fixed pipe!
Sorry for the long winded ramble. Any help appreciated.
Lee
Lee
