Recommend me a approved installer in the midlands
I'm new on here and interested in getting my car converted to LPG. Its a 1.6T engine on a VX Insignia.
Who would you recommend, which LPG system to go for and reason and costs involved?
Thanks.
Thanks.
Re: Recommend me a approved installer in the midlands
Simon.......
Most likely going to be direct injection.. What's the year of the car and can you find the engine code @raimon?
Hi, its a 2012 and engine code is A16LET.LPGC wrote: Fri May 31, 2019 6:39 pm Most likely going to be direct injection.. What's the year of the car and can you find the engine code @raimon?
Just done bit of research i found articles say its a multi point injection.
It may be multipoint but is it port injection, where the injectors squirt fuel into the inlet manifold before the valves or direct injection where they squirt directly into the combustion chamber. If port injection, it's a simple conversion, if direct injection it isn't. I would have thought 2012 would be port injection but it might be one of the first direct injection engines.
Yeah its port injectionGilbertd wrote: Thu Jun 06, 2019 6:49 pm It may be multipoint but is it port injection, where the injectors squirt fuel into the inlet manifold before the valves or direct injection where they squirt directly into the combustion chamber. If port injection, it's a simple conversion, if direct injection it isn't. I would have thought 2012 would be port injection but it might be one of the first direct injection engines.
I've replied to your PM @raimon.
Thanks, Simon
Thanks, Simon
