Faulty filter or not?
Posted: Wed Aug 09, 2017 11:47 am
All of a sudden my car wont switch to gas and I get some warning beeps from the LPG system when I start the engine. I have a stag system fitted to an MG ZT 2.5 V6 petrol engine. When I connected it to my computer there is a warning/error that says the system needs to be checked by and LPG installer.
I thought that it could be the filter so I tried another one which I had lying around it seemed to work it switched to gas but I could smell gas so I checked the filter and gas was leaking from it so I put the original back on and again car does not switch to gas and the warning beeps are back when I start the engine.
I use a 12mm to 12mm Vapour Gas Filters and have ordered a replacement.
The question is if it is indeed the filter (I don't know for sure until the new one arrives) then I don't seem to having much luck with them as they don't seem to last a year I only do a small amount of miles around 2 to 3 k per annum. Is this normal or do I need a higher spec filter?
Thanks,
Pat
Thanks,
Pat
