Page 1 of 2
Nissan Skyline 350GT converted by LPGC
Posted: Fri Dec 23, 2016 2:54 pm
Recently converted this Nissan Skyline 350GT (3.5V6) for someone who frequents this forum, he's been asking me to put pics up but I've been too busy until now. In fact I still have to check calibration on the Elgrand I've just converted, same engine really just with a different plenum, I'll be doing a thread on that too later.
720x200 internal tank, KME Nevo, Romano HD reducer, single MJ injectors, Flashlube.
The ECU is hidden beneath the battery cover, the reducer is hidden beneath the coolant expansion tank, filler is hidden behind the number plate. The owner intends on making the number plate hinged but for now it is easily removed by taking out a couple of machine screws.
Engine bay, job done
You wouldn't normally see the reducer even from this angle but this pic was taken with the expansion tank removed, which is mounted on a slide mount at the bottom and comes out easily with removal of one bolt.
Job done but engine trim cover off
Side view
top view
preventing swarf from entering engine from drilling and tapping, bit of sponge carpet glued to rubber pipe shoved well down ports to below spud location before drilling. Spuds fitted and injector break wiring are done in this pic. I forgot to take a pic with the discrete MJ injectors in place but they fit directly on top of those spuds with pipe length between injectors and spuds of about half an inch. Injectors are fed with gas from LPG feed manifolds that are also sited out of view under the outer edges of the lower part of the plenum.
upper upper and lower upper plenum bits off
putting injector break wiring in
coming to bits, upper upper off
filler behind number plate. I didn't cut that great hole out of the bumper it was already there.
before I replaced securing bolts with tapered machine screws
tank, 720x200 a strange size but owner didn't want taller as boot is already small and shallow. Even at only 200 height the 720 tank is 62.5L
job done
Been a few years but I've converted some of the 'mental' 2.6 straight 6 twin turbo Skylines in the past, some with big boost and very high bhp figures.
Re: Nissan Skyline 350GT converted by LPGC
Posted: Fri Dec 23, 2016 4:58 pm
by 57jam89
And it's a great conversion, runs spot on and can't tell the different from running on petrol.
I'm well happy with it.
Many thanks Simon.
Posted: Fri Dec 23, 2016 8:32 pm
57jam89 wrote:And it's a great conversion, runs spot on and can't tell the different from running on petrol.
Many thanks Simon.
Thanks Simon! I appreciate you coming all the way from London, suppose you know who gets the results
Merry Xmas and best regards, Simon.
Posted: Sun Jan 01, 2017 1:22 pm
by 57jam89
Well I have just filled her with gas for the 1st time, got 59.97 litres in.
Still got to sort out the hinged rear plate, I will post pictures then I do.
I also changed the long 6mm bolt for a short one holding the lube bottle.
Thanks again simon.
Posted: Tue Jan 03, 2017 5:11 pm
57jam89 wrote:changed the long 6mm bolt for a short one holding the lube bottle.
Thanks again simon.
No probs mate, yeh I could/should have fitted a slightly shorter bolt to hold the lube on, it didn't seem to be a problem though else I'd have probably just cut it shorter without having to remove it.
Posted: Sat Jan 07, 2017 4:48 pm
by 57jam89
Sorted out the rear plate today -
It's got a plastic hinge which is bolted to the number plate frame and glued to number plate with a small magnet which is again glued to the plate to keep it up/shut.
Posted: Sun Jan 08, 2017 4:07 pm
Nice one Simon! Will you be adding a second magnet?
Just gonna reply to your PM about changeover switch wiring route / swapping the radio.
Cheers, Simon
Posted: Sun Jan 08, 2017 4:43 pm
by 57jam89
LPGC wrote:Nice one Simon! Will you be adding a second magnet?
Cheers, Simon
Hi Simon,
Don't know if it needs 2 magnets because it's a strong one, I will give a try for a few weeks to see how I get on with.
Thanks.
Posted: Tue Jan 10, 2017 6:08 pm
by 57jam89
I have just run tank full to empty, 59.95 litres does about 290 miles 22mpg.
Well happy with that.
Posted: Tue Jan 10, 2017 6:32 pm
Great stuff mate
Posted: Thu Apr 27, 2017 7:09 pm
by 57jam89
Hi Simon,
How you doing? Busy?
Just a quick one , maybe thinking of getting the GT remapped, would this mean the lpg would need redoing as well?
Cheers.
Posted: Fri Apr 28, 2017 3:26 pm
Hi Simon,
Been very busy until today, just a few repairs customers today.
Ideally it's best to check LPG calibration following a petrol remap but on a normally aspirated engine there isn't really much anyone can do to change engine torque/power levels much unless the engine is modified too. I don't think your fuelling on LPG will be far out following the limited changes remap of a normally aspirated can do, would be different on a turbo where remap can easily change boost levels etc.
Cheers, Simon.
Posted: Tue Jul 11, 2017 9:09 am
by 57jam89
Hi Simon,
Looks like the same has happened to your photobucket account as mine!
Just a quick question simon, is there a one way valve on the intake to the tank?
I'm maybe thinking of changing the tank to a cylinder one depending on size etc and still fitting in spare wheel in the boot. I would need to remove the tank to have a proper measure.
Posted: Fri Jul 14, 2017 4:43 pm
H Simon,
Same has happened to everyone's Photobucket account. I'm looking at other photo sharing services... those that are still free to use. Just waiting for Photobucket's email that says my pics are ready to download.
Yes there's a one way valve on all tank inlet valves, yours will work OK so you can confidently remove the filler pipe. The most common failure of one way valves is on 4 hole tanks when whomever fitted the filler valve screwed it on the tapered threads too tightly breaking the one way valve.
Posted: Fri Jul 14, 2017 8:14 pm
by 57jam89
Hi Simon, someone recommended Cubeupload to me, I haven't tried it yet.
Posted: Tue Aug 01, 2017 6:54 am
by 57jam89
Hi Simon, any luck with getting your pictures back/downloaded from photobucket?
I'm having problems getting mine.
Thanks.
Posted: Tue Aug 01, 2017 7:51 pm
57jam89 wrote:Hi Simon, any luck with getting your pictures back/downloaded from photobucket?
Thanks.
It seems I can get a few at a time but doing it that way is a pita. Initially it seemed the download library facility would allow me to download all my pics at once if I selected the route folder, which proved incorrect when I got an email link that only sent me the couple of pics that were in my route folder! I am still waiting for an email with all my work pics in, but after waiting so long I doubt it will happen.
Posted: Tue Aug 01, 2017 10:16 pm
Thanks.
It can be done but a lot of the time just recently it is failing to connect to the Captcha website to do the verification. I suspect it is due to the sheer number of people downloading their pictures to then upload them to Imgur instead. When it does finally connect, it downloads all your pictures to a single zip file. After I'd managed to get all of mine off, I eventually found the close my account menu item. It asks you why you wish to close the account, so I told them in no uncertain terms.
Posted: Wed Aug 02, 2017 4:57 pm
Gilbertd wrote:57jam89 wrote:Hi Simon, any luck with getting your pictures back/downloaded from photobucket?
Thanks.
Thanks for that, I'll try again when on a proper internet connection, which will have to wait until I'm back from holiday. When I've got all my pics I'll probably close my account and explain why too.
Posted: Sat Aug 19, 2017 5:24 pm
by 57jam89
Simon, any luck with getting pictures from photo bucket?
I try 3/4 times every week but can't get any pictures back/download from them!
