Kme ecu drain?
luke123
Kme ecu drain?
#1 Post by luke123 »
Hi im having a drain on the suzuki ignis i lpg converted.
When i remove the fuse from the main battery positive the car seems to be ok running on petrol but when i put the fuse back in the voltage from the battery doesnt last long, i have a good working alternator.
Could anyone tell what pins i need to check to make sure the ecu is powering down
Kind regards luke
Re: Kme ecu drain?
#2 Post by Gilbertd »
How much current is it drawing when switched off?
Re: Kme ecu drain?
#3 Post by LPGC »
No need to check any pins, when the ECU powers down you lose interface connection.
Also, if it is switched to gas and no lights are on the switch it will be powering down.
Uff, old thread I just realised..
