Nevo Pro BMW E39 killing injectors.
Posted: Sat Mar 26, 2016 12:58 am
by roggy roo
Started to Kill petrol injector signal only when Nevo is active, on petrol Nevo off, no problems.
Leave it ticking over on petrol waiting for changeover conditions it will kill one of the injectors, engine runs rough and there's no injector signal in the Nevo software, that'll log the fault though.
Turn the engine off and on again, and the signal returns and I'm back on petrol.
Mapping and vacuum
Vacuum values always between 1.03 and 0.99 bar, no matter the engine speed.
I'm guessing I've put the vacuum line in the wrong place on the inlet side, just after the MAF sensor, anyone know where I should tap the line to get a good vacuum pressure.
I also can't get Nevo to connect to the Ecu via OBD, there are only 2 active signal lines on the E39, connecting to either or both lines.
Re: Nevo Pro BMW E39 killing injectors.
Posted: Sat Mar 26, 2016 7:48 pm
roggy roo wrote:Started to Kill petrol injector signal only when Nevo is active, on petrol Nevo off, no problems.
What are you calling Nevo active / Nevo off (pulling the fuse or something)? Nevo is usually active whenever the ignition is on...
roggy roo wrote:Leave it ticking over on petrol waiting for changeover conditions it will kill one of the injectors, engine runs rough and there's no injector signal in the Nevo software, that'll log the fault though.
That could be due to mismatching petrol injector / LPG injector channel, confusing striped unstriped injector break wiring, bad initial calibration (or in-appropriate pressure / nozzles), defective ECU. Over the years I've known a couple of KME ECU's not connect petrol injector wiring properly, in one case the ECU was only weeks old - On gas there'd be no problem, on petrol a misfire on one cylinder due to the problem. But I suspect the ECU isn't at fault here.
roggy roo wrote:Mapping and vacuum
The vacuum (engine) side of the throttle body... Because there is no vacuum at the other (air filter) side of the throttle body.. and yours isn't Valvetronic? I expect you'll have a few questions later!
roggy roo wrote:I also can't get Nevo to connect to the Ecu via OBD, there are only 2 active signal lines on the E39, connecting to either or both lines.
Least of your worries at this point (Nevo Pro then?). Before worrying about this, cure the other problems and be confident there's no ECU issue (if broken in one way, maybe broken in another too). Though would suspect you've been wiring the OBD up wrong.
All stuff your supplier can give tech support on anyway?
Posted: Sun Mar 27, 2016 8:58 am
Is it BM's or Merc's that shut down a cylinder if they detect a problem?
Posted: Sun Mar 27, 2016 11:29 am
by roggy roo
If I turn the LPG system off from switch, then it's off/inactive.
Apparently the E39 will go into batch fire mode, if there are problems with the inlet cam sensor signal.
I did have a problem with the cam sensor and replaced it.
Shouldn't affect this though if the sensor signal's good enough to run on petrol, then Nevo shouldn't be messing about reporting a lost signal and killing the outward bound signal to the injector.
Thing is it's not consistent, worked OK(ish) for a week or two, needed tweaking/mapping, then it started killing/losing the injector signal.
Only did it twice yesterday.
I've had the LPG system turned off for weeks, got bored/peed off looking the laptop, it cutting out, running fluffy etc, just needed a break from faffing about with it.
Had a search about on here for threads, apparently there's a spare/unused vacuum outlet on the M54 inlet manifold somewhere that I've missed, after throttle.
Posted: Sun Mar 27, 2016 7:22 pm
Gilbertd wrote:Is it BM's or Merc's that shut down a cylinder if they detect a problem?
A lot of modern vehicles will do that, Mercs particularly noted for doing it at the first sign of a misfire and on relatively old models too.
roggy roo wrote:If I turn the LPG system off from switch, then it's off/inactive.
Very much agreed but at least while the fuse is in the LPG ECU is reading petrol injector durations etc.
roggy roo wrote:Apparently the E39 will go into batch fire mode, if there are problems with the inlet cam sensor signal.
Never known that happen, not saying it doesn't but have seen many with OBD reported cam sensor issues (at least latent error codes), seems a common thing with them.
roggy roo wrote:Shouldn't affect this though if the sensor signal's good enough to run on petrol, then Nevo shouldn't be messing about reporting a lost signal and killing the outward bound signal to the injector.
Unless the mapping is wrong enough to cause a misfire on the cylinder and then fuelling is switched off to that cylinder (Gilbert's point). One thing's for sure - If you're seeing around 1 bar MAP all the time and your engine isn't Valvetronic then the fuelling cannot be correct at all loads. The combination of incorrect MAP signal and incorrect mapping is is by far the most likely cause. If not then it's back to the other points in my previous post (wiring / dodgy ECU's).
roggy roo wrote:Had a search about on here for threads, apparently there's a spare/unused vacuum outlet on the M54 inlet manifold somewhere that I've missed, after throttle.
Never noticed, always drilled my own. What engine is this? Does it feature idle air /near port crankcase breather system / Valvetronic?
