RPM signal
Posted: Tue Jan 12, 2016 3:21 pm
As mentioned elsewhere I have a Mercedes CLK320 that I am working on, all the bits are installed and plumbed in with the exeption of the last three wires
The RPM one is probably the most important of those left, but the car has a coil for each plug, but just to add to that it actually has 2 coils for each plug, so the earth for one cylinder may not work terribly well, is there an RPM signal at the ECU I can use?
the other twop are the left and right bank lambda, which I would like to have, ideally to be picked up at the ECU end of the loom
