I have been a very silly boy this weekend and gone and bought a 2007 e63 AMG estate. (pics here if you are interested - http://www.utterpiffle.com/Cars/Benz/E63/).
Need some advice please
It looks like several people in Germany have LPG'd this fantastic engine and I'd like to do the same. I don't claim to be an expert, but have successfully converted about 10 cars over the years, including my outgoing 1999 e55 AMG, so I have a basic understanding - at least of the concepts.
I have two things rattling around my mind - firstly, what kit should I buy and secondly, where the bloody hell will it go! That engine bay is stuffed...
I do a 1000 mile round trip to Germany every three weeks, so I should probably get the spanners out fairly quickly!
The e55 will be broken for parts, so if I could use some of my existing kit, that would be great, but not sure if this will be possible. The new car is about 64hp per cylinder on full throttle.
- 2x magic III 250/350 hp reducers - these worked brilliantly in my e55, but that was 'only' 354hp. 8mm pipe front to back, then split into two sixes after the solenoid into the reducers. They were set to 1.2 bar, but think they go up quite a bit more. I do like the compactness of the Magic units though - I see they sell higher capacity ones as well (350/450hp), so maybe two of these be suitable? - there really is no space under that bonnet though!
- Magic injectors - nozzles drilled to 2.5mm - again, they've been brilliant for 35k miles. Can I use these if I just drill out the nozzles further, or even remove the nozzles completely? Will it idle if I do this? Documentation on these is sketchy at best, but seems to suggest they will run up to 60bhp per cylinder.
- Romano RISN ECU - this I want to replace this anyway as I've used it on 4 different cars since 2008 and it is probably very out of date - although I did update the firmware 2 years ago. Options other than Prins? Is the stag 300 system any good? It advertises itself as self mapping, which I like the sound of.
- Bosch stand-off adaptor thingies. Not sure of the name, but they raise the injector rail 10mm and give lpg inputs. I want to use these again as would prefer not to drill the inlet manifold. Anyone see any problem with this, other than not being being able to fit the engine cover / air filters back on easily?
I guess I have a budget of around a grand for parts.
Anything else I need to consider for converting this car. Has anyone ever done one? Where the hell do I locate the reducers/filters! Did I say there is no room in there?!
Excuse the long winded message, but any advise would be very much appreciated.
Oh yeah, look how little space there is in there!
