MoT fail on O2/Lambda score
Posted: Fri Nov 14, 2014 10:07 am
Hi all
My Jeep Cherokee, has its problems but running on gas is not one of them. In fact it runs much better on gas than on petrol.
I've owned it for a couple of years now, and in that time it's never run very well - if at all - on petrol once it's warmed up.
One LPG tuner told me the lambda senser was not working so I replaced it - the new one came up on the scanner as not working either... a broken wire I think.
Anyway - runs and drives ok... on open loop (except on petrol as I said).
Last year passed it's mot on emmisions ok. Since then I've put a manual stepper on and tuned it to run lovely.
I know there's a small crack in the exhaust manifold - will be fixing that today - the mot tester ran the revs up to overide any air leaks on the test - I don't think he discovered the manifold crack.
Made no difference.
Problem is it failed the MOT on O2 too high.
Questions:
1. I know there's a small crack in the exhaust manifold - will be fixing that today.
2. Adjusting the stepper to run lean - less gas - make the combustion burn more efficiently just for the MOT?
3. Will the short term and long term fuel trim scanner readings help me get the O2 down?
4. Suggestions?
thanks
Paul
Won't let me post a picture of the fail sheet...so
fast idle test 1 min max
CO level = 0.01% pass - 0.30
HC level = 69ppm pass - 200
Lambda = 1.15 fail 0.97 1.03
fast idle test 2 min max
HC level = 140ppm pass - 200
Lambda = 1.38 fail 0.97 1.03
Natural idle test
CO level = 0.01% pass - 0.50
- just noticed the fuel type is down as unleaded, should it be gas? Is there a gas option on his analyser, MOT menu?
Made no difference.
Questions:
4. Suggestions?
thanks
Paul
Natural idle test
