Intermittent Misfire and Hesitation 2002 Discovery V8
Posted: Mon Sep 22, 2014 6:35 pm
I advised someone to post the V8 LPG problem here but they were unable to register so have pasted it in for them
" Has anyone any experience of LPG. I've just bought a 2002 Discovery V8 to play with so I can spend some time getting, and keeping the XJ in top condition. However, the Disco has an intermittent misfire/hesitation (difficult to describe) when running on LPG. It tends to happen when it gets warm and only at lower speeds and revs. When it happens, I can switch it to petrol and it runs ok. Get the speed up to about 50 and switch back to gas and it doesn't misfire until you drop the speed again. The MAF sensor has been changed, as have the plugs and leads. There are no leaks on the intake side that I can find. I am not getting any codes since I've done the plugs and leads although the misfire/hesitation remains. Whilst actually putting the problem down in words on here, it's made me realise that it's seems more than a single cylinder misfire, more like the engine switching off momentarily. If you take your foot off the throttle and replace it, all is ok until it happens again. My thoughts at present are the link between the lpg ecu and the throttle position sensor or the rev counter as I've found a couple of wiring faults on the lpg system which I've repaired. I suppose it could be that a solenoid in the lpg system is switching off and on intermittently. I know there is a solenoid next to the vapouriser, are there any more? Does anyone have any idea of what the problem may be or reckon my way of thinking is on the right track. Any help and advice you can give would be appreciated. "
