Hi all just got my RR dont know much about lpg
when I got it it kept cutting out when switched to lpg
I tried today and it seems to run now on lpg. So the dash
switch says but how do I know if it is running on lpg and not
petrol
andy
RANGE rover lpg
Re: RANGE rover lpg
What model Range Rover (P38 I think from the other forum) and any idea what LPG system you have? One easy test you can do is pulling the petrol pump relay when running. If the engine splutters and dies then it's on petrol, if it carries on running normally, it's on LPG.
flyingbanana
- Junior Member
Re: RANGE rover lpg
Yes p38 I will try and find it and have a go
thanks
thanks
flyingbanana
- Junior Member
Re: RANGE rover lpg
Would you be able to smell if it was on gas from exhaust
than on petrol
than on petrol
Re: RANGE rover lpg
Maybe although it would only be really noticeable if it was running rich so you get unburnt fuel out of the exhaust. Fuel pump relay is the single one at the front of the fusebox, nearest the battery, roughly in the centre, RL12.
flyingbanana
- Junior Member
Re: RANGE rover lpg
Ok thanks I will try tomorrow
andy
andy
Re: RANGE rover lpg
Contrary to popular belief, often the only way of knowing if you are running on gas is to look at the switch. If anyone tells you that it will be down on power, will have a permanent Check Engine light on or any of the other ills often attributed to LPG, they are wrong. It should not be possible to tell the difference simply by driving the car. In fact, mine is smoother on gas than on petrol but I put that down to the petrol injectors suffering due to lack of use.
Re: RANGE rover lpg
flyingbanana you dont own a yellow mk1 escort do you?
