Using LPG to "Increase" performance ???
Posted: Wed May 07, 2014 11:45 am
alright peeps,
I have a Merc 230 Supercharged running about 200 brake with a max of 7 psi from the charger.
I have a dream 21 lpg system
I can get a smaller puller which ups the boost buy 2 -3 psi
But the pulley is designed to be used in conjunction with the later OBD2 type ecu which can be remapped but as I have a early car which has a OBD1 ecu which is not mappable and can only be "chipped" and the "Chip" is no longer available or prohibitively expensive
So what I was thinking of doing is getting the pulley fitted and then using the LPG to up the fuelling to match the increased air intake ??
Is this possible as I have not got a clue about these things !!
Brett
Brett
