Using LPG system question.
LondonMerc777
- New member
Hi - i only recently bought a car with LPG - i have been leaving it on all the time and let it cut in when it's ready ... is that ok - or should i manually press the button when the engine is warm? cheers.
Re: Using LPG system question.
Nope, leaving it on all the time is how it is designed to be used. Then it will changeover as soon as it is ready and not wait for you to do it. You would normally only manually change over to petrol if for some reason you didn't want it to run on gas.
