Hi guys,
I am trying to find a pin out diagram for the KING breed of ECUs, it looks like it will be the same as the OMVL and AEB, I in my wisdom removed all the unused/un-needed wires from the ECU connector to ensure there was no chance of any loose/cut wires touching anything it shouldn't.
However I need to make sure the gas injector wires are correct as I am not 100% certain they are, so if anyone has the info or can take a PHOTO of the ECU plug showing the gas injector wires then that would be great.
Many Thanks
ECU pin out diagram
Re: ECU pin out diagram
I forgot to mention, that it is bank/group 2 I am interested, injectors E and F, just the ECU pin numbers would be fine
Many Thanks
Many Thanks
