After pratting about for a week I finally got the Shogun running on gas
Using the wisdom gathered from this forum I think it's ok (well nearly)
Performance wise it's no different, pulled 6000rpm through the gears in power mode up to 100 mph no problem ( private road officer)
Cannot get my head around the map settings yet, any pearls of wisdom?
Slightly rough idle, slight cough from the exhaust and not quite as smooth at idle as on petrol, any ideas?
Changed the Platinum plugs for Iridium but left the gaps as they came out of the box. Do you think I should close the gaps up a little?
Leads have done 130k I think, they may have been changed before I got the old girl.
The level sender is talking bo--ocks showing empty. Is it because I only put 18 litres in.
I'm impressed with the price of LPG. Put 4 gallons (18.2 litres) of petrol in the little tank which cost £24. Put the same in the LPG tank and it cost £13, not bad. If the cheap place had been open it would of been a tenner.
Thanks for your help
Rob
