xj40 multi point stag system
josht
#1 Post by josht »
I have a xj40 running a multi point lpg system well just about running. It overfuels on idle and isnt as smooth as it it is on petrol i was told somtime ago that xj40 wernt compataple to the stag multi point setup because of the 2.5 ohm injectors. Just wondering if any solution was ever found for this? Anyone know of a place that would take a look at it for me?
Re: xj40 multi point stag system
#2 Post by classicswede »
Not down to injector resistance but method of firing injectors.
I take it you LPG injection times are down at around 2ms on tick over?
josht
#3 Post by josht »
Yea i think theh were last time i plugged it in il plug it in again tommorow and have alook. Iv herd of other xj40's running the same system just not sure how they did it.
josht
#4 Post by josht »
I just checked and yes its down at 2 ms. What dose that mean? Thanks in advance
Tubbs
#5 Post by Tubbs »
Its a full or half group system, and not a sequential injection system.
#6 Post by classicswede »
Its full group, meaning that the injectors fire twice per cycle. AEB have a great way around this by filtering the second pulse out and then firing the injector for twice as long so your tick over would be opening of 4ms instead of 2x2ms. The LPG injectors can not be acuratly controlled at such low opening times. The other option is to opt for smaller injector nozzles or reduce the gas pressure to gain a good idle but this usualy ends up casuing the system to switch back to petrol under high load as you run out of injector duration.
josht
#7 Post by josht »
Thanks buddy so i supose my options are to have a play with different nozzles and pressures to make it idle right and then switch to petrol for hard driving or swap to a different setup.
hardcorepit80
#8 Post by hardcorepit80 »
You can play with nozzles size and pressure, but you need to connect to the controller and set it up properly, otherwise you won't be able to do much...
It's like trying to fix a car without opening a bonnet...
stype3
#9 Post by stype3 »
a different option may be to go for faster lpg injectors? such as the magic jet ones?
josht
#10 Post by josht »
I can connect but it was a year ago since i had a play so il have another try . Faster injectots would shorley help? I dont mind taking it in to let the experts do it but i dont want to waste there time. Any recomendations west mids?
#11 Post by classicswede »
Tubbs will be the nearest to you
josht
#12 Post by josht »
Is it the injectors that strugle to fire that fast or the ecu?
Tubbs
#13 Post by Tubbs »
07931 459385. What system is it ?
#14 Post by classicswede »
:roll: Stag - read the thread title :wink:
